Problem for take control HTTP in ACE
I have a problem, when I disconnect the Server with IP 10.24.8.200 or the server with IP 10.24.8.201 the other server that is alive take 50 seconds in take the control of HTTP service, but the icmp of 10.24.16.10 always is active.
what are I do wrong?
how can i have 10 seconds for take the control of HTTP?
Configuration
ACE-MOD6/integracion1# sh runn
Generating configuration....
access-list anyone line 8 extended permit ip any any
probe http get-index
interval 5
faildetect 5
passdetect interval 10
expect status 200 200
rserver host Srv1
ip address 10.24.8.200
probe get-index
inservice
rserver host Srv2
ip address 10.24.8.201
probe get-index
inservice
serverfarm host servers
rserver Srv1
inservice
rserver Srv2
inservice
class-map type management match-any ADM-CONTEX-SERV1
2 match protocol telnet any
3 match protocol ssh any
4 match protocol icmp any
class-map type http loadbalance match-all Check-Headers
2 match http url .*
3 match http header Host header-value "10.24.16.*"
4 match http header User-Agent header-value ".*MSIE.*"
class-map match-all VIP-10-HTTP
2 match virtual-address 10.24.16.10 tcp eq www
class-map type http loadbalance match-all other-HTTP
2 match http url .*
policy-map type management first-match ADM-CTX-SERV1
class ADM-CONTEX-SERV1
permit
policy-map type loadbalance first-match L7-logic
class Check-Headers
serverfarm servers
class other-HTTP
serverfarm servers
policy-map type loadbalance first-match lb-logic
class class-default
serverfarm servers
policy-map multi-match client-vips
class VIP-10-HTTP
loadbalance vip inservice
loadbalance policy L7-logic
loadbalance vip icmp-reply active
interface vlan 60
description inside
ip address 10.24.8.5 255.255.255.0
access-group input anyone
access-group output anyone
service-policy input ADM-CTX-SERV1
no shutdown
interface vlan 233
description outside
ip address 10.24.16.5 255.255.255.0
service-policy input client-vips
no shutdown
ip route 0.0.0.0 0.0.0.0 10.24.16.1
10.24.16.10 is the Virtual IP that represents the Application to the world.
It will only go down when both real servers (10.24.8.200 & 10.24.8.201) are down.
When one of the two real servers goes down, ACE forwards all traffic to the remaining
Real server.
As per the your probe config, ACE sends probes to the server (marked as passed) every 10 sec (interval).
Your current probe config dictates that ACE should wait for 5 consecutive number of failed probes b4 marking the server as failed.
Which makes it 50 (10+10+10+10+10) Secs.
If you want ACE to detec failure earlier then you can tune "interval" & "faildetect" values
under probe configuration
for e.g
replacing
interval 5
faildetect 5
with
interval 4
open 2
recieve 2
faildetect 2
will enable ACE to detect server failure in 8 secs.
Syed Iftekhar Ahmed
