Problem in transfering files from servers to servers
tharunraj22
We have deployed an ACE 4710 and its working perfectly.  But the problem is that after I chage the default gateway of the servers I am not able to transfer files from one server to other.  Is there any special configuration needs to be done on ACE to acheive this?
Other than copy Ping, telnet and everything is working fine from the servers. These servers are in the same subnet & VLAN.
Tharun
Daniel Arrondo Ostiz
Hi Tharun,
If the servers are in the same vlan and subnet as you mentioned, then, they would not need to go through the ACE at all to communicate between each other.
Daniel
Hi Daniel,
That's true but the file transfer is happening properly once we change the gateway of the servers from theACE IP to the old gateway.
Tharun
Hi Tharun,
In that case, you should focus on the new traffic flow to understand how the ACE is affecting it. A traffic capture on the servers would allow you to see if the traffic is really going directly between them or if it's somehow going through the ACE.
Daniel
