Problem redirecting HTTPS trafic using WCCP on a Cisco 6509
michaeljensen
Community Member
I am implementing af Ironport web scanning solution in a current network and i have som problems with HTTPS trafic.
I am using the following command.
ip wccp 70 group-list 9 password xxx accelerated
interface Vlan2
      ip wccp 70 redirect in
access-list 9 permit <Ironport IP>
on the Ironport the "
So i think the problem is in my WCCP configuration.
Can you reset the WCCP session between the Ironport and the 6K, SPAN the interface where the Ironport is connected, re-establish the WCCP session and collect the captures in pcap format, then upload them?!
Can you get the show ip wccp commands from the 6K to check the WCCP status?
