Problem to access servers
fabrice.demierre
Community Member
I’ve created two SMTP services and a content with this both 2. When I try to access the vip no problem but when I try to access directly the server (real ip of the server) through the CSS I arrive to an other SMTP sever.
I use two CSS 11503 with version 7.40.0.04
Thanks for your help
Fabrice
Gilles Dufour
Fabrice,
let me first recommend you to upgrade to a latest 7.40 version. The one you currently use is the first one of this train and many many fixes have been introduced since.
Regarding your problem, are you saying that each time you want to access server-1 you get to server-2 and vice versa ?
Is it all the time ?
If you're going to a server address directly, the CSS does not do anything to the traffic. It just routes it.
Did you capture a sniffer trace in front and back of the CSS to see if the CSS modify anything ?
Could you send us your CSS config ?
Did you verify mac address on the CSS for the server ip ?
Gilles.
