Problem with ACL in CSS-to-CSS redundancy configuration
tkukol
I have two CSSes - first is master, second is backup. When I enable ACL on master CSS, it can't see more the backup CSS. My first rule is to allow all traffic between both CSSes. I have CSS 11050 with 4.10 Build 10.
Here is a part of my config:
--- begin ---------------------------------------------------
!************************* INTERFACE *************************
interface e8
bridge vlan 254
description "css1 <-> css2 (net 192.168.254.0/30)"
!************************** CIRCUIT **************************
circuit VLAN254
ip address 192.168.254.1 255.255.255.252
redundancy-protocol
!**************************** NQL ****************************
nql n_csw_to_csw
ip address 192.168.254.1 255.255.255.255
ip address 192.168.254.2 255.255.255.255
!**************************** ACL ****************************
acl 1
clause 1 bypass any nql n_csw_to_csw destination nql n_csw_to_csw
apply circuit-(VLAN254)
--- end ---------------------------------------------------
Where is the problem? Is it a bug in my current version or an error in my configuration?
Thomas Kukol
awo
at first step read http://www.cisco.com/warp/customer/117/css_packet_trace.html
and trace your unworking configuration
if you give flow option 0xffffff you should see why ACL didn't pass app traffic..
second idea is to use normaln acls w/o nql....
with permit keyword...
share expirience here again 8-)
