Problem with content engine 5.5.19
bala020881
Dear All,
While accessing website using this proxy I'm facing some issues, but if I access without proxy it works fine.
WITH PROXY
Response Headerspretty print
HTTP/1.1 302 Object moved
Server: Microsoft-IIS/5.0
Date: Wed, 22 Dec 2010 08:33:16 GMT
X-Powered-By: ASP.NET
Content-Length: 132
Content-Type: text/html
Cache-Control: private
Proxy-Connection: Close
Request Headerspretty print
POST http://xxx.com/submit_form.asp HTTP/1.1
Host: xxx.com
User-Agent: Mozilla/5.0 (Windows; U; Windows NT 6.0; en-US; rv:1.9.2.13) Gecko/20101203 Firefox/3.6.13 (.NET CLR 3.5.30729)
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-us,en;q=0.5
Accept-Encoding: gzip,deflate
Accept-Charset: ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive: 115
Proxy-Connection: keep-alive
Referer: http://xxx.com/welcome.asp
Cookie: ASPSESSIONIDSAQTRQQR=GFCJOKHBFAJCBNBKDEOEONNA; ASPSESSIONIDSCDQQDAA=IMIELKDBOOBDMIJGEEJMGFFO
WITHOUT PROXY
Date: Wed, 22 Dec 2010 08:38:03 GMT
Pragma: no-cache
Cache-Control: private, no-cache
Content-Length: 131
Expires: Tue, 21 Dec 2010 08:38:02 GMT
GET /welcome.asp HTTP/1.1
Host:xxx.com
Keep-Alive: 115
Referer: http://xxx.com/welcome.asp?language=E
Can someone help me to fix this issue in content engine
Balajirajah P B
sachinga.hcl
Level 10
Level 10
Hi Bala,
As you can see that with proxy the POST method is there like
While without proxy the method used s GET as follows:
SO check on your content engine for which method is needed to present the correct page.
As their names imply, both HTTP GET and HTTP POST use HTTP as their underlying protocol. Both of these methods encode request parameters as name/value pairs in the HTTP request.
The GET method creates a query string and appends it to the script's URL on the server that handles the request.
The POST method creates a name/value pairs that are passed in the body of the HTTP request message.
We can send data to the data processing page by both the GET and POST methods of a form. Both methods are used in form data handling where each one has some difference on the way they work. We will discuss some of the differences.
As you have seen there is a character restriction of 255 in the URL. This is mostly the old browsers restriction and new ones can handle more than that. But we can't be sure that all our visitors are using new browsers. So when we show a text area or a text box asking users to enter some data, then there will be a problem if more data is entered. This restriction is not there in POST method.
In GET method data gets transferred to the processing page in name value pairs through URL, so it is exposed and can be easily traced by visiting history pages of the browser. So any login details with password should never be posted by using GET method.
As the data transfers through address bar ( URL ) there are some restrictions in using space, some characters like ampersand ( & ) etc in the GET method of posting data. We have to take special care for encoding ( while sending ) and decoding ( while receiving ) data if such special characters are present.
There are some special cases where advantage of using GET method is , one can store the name value pairs as bookmark and directly use them by bypassing the form.
Kindly check  the below mentione URL for more details on GET or POST method:
http://www.diffen.com/difference/Get_vs_Post
Sachin GARG
