Problem with CSS replication script
m.magnani
Community Member
Hi all.
I am experiencing troubles with the script "commit_redundancy". I can see from the debug (-d switch) that the problem arises when Master CSS tries to remote copy the file tmp.cfg to the Slave CSS because it doesn't exsist. Disks are almost empty so we have no disk space problem.
Here is the logs:
CSS11050# script play commit_redundancy "-d a.b.c.d"
Checking available disk space on systems ...
Checking the disk space locally before continuing with the script.
COMMIT_REDUNDANCY Version: 3.16
Verifying app and redundancy configs ...
Verifying that ip redundancy is activated on Master switch.
Verifying that app session is up with backup switch.
Making sure app session is up.
Seconds to wait before calling it quits: 120
Checking the disk space remotely before continuing with the script.
Checking local and remote switch versions ...
Storing the running code versions of the local and remote switch.
Storing the local switch's version.
Retrieving the remote switch's version.
Checking remote version for 4.0
Checking Master redundancy-config for redundancy-protocol set
and if so storing it in variable MASTER_IP.
Verify that the Ip Address specified is the Backup's Ip Address.
Checking Backup app session up....
Saving Master running-config to startup-config and archiving
startup-config.
Copying running-config to startup-config.
Archiving startup-config.
Copying startup-config to a temp file tmp.cfg.
Swapping Master and Backup ip addresses in tmp.cfg for app
Checking for multiple APP sessions between redundant peers.
App Session IP: a.b.c.d, Local IP address: a.b.c.d-1
Checking IP Address size differences : <a.b.c.d> <a.b.c.d-1>
Adding APP session IP length difference to LOCALCONFIG byte size : 0
Adding APP session IP length difference to REMOTECONFIG byte size : 0
Removing CIRCUIT and INTERFACE modes from tmp.cfg.
Checking if ip redundancy master is set
Checking redundancy state....
Working
Using rcmd to copy tmp.cfg to a file on Backup switch.
Error in file copy. File does not exist.
CSS11050#
Thanks in advance.
Massimo Magnani.
Gilles Dufour
I checked our database and for 50% of our customer, the problem disappeared after a software upgrade.
For 20% of them, we created an RMA to replace the CSS.
For the rest, the problem disappeared by itself.
So, I would suggest to start with the software upgrade if you are not already running the latest version.
There is new modification done to this script very often, so it's hard to say which bug fixed this issue.
Gilles.
