Problem with CSS11503 and Trunking
cantorb
Community Member
I am very new the the CSS world. I've only delt with CSSs that were already up and running in production. I am now attempting to bring up a pair of 11503 with box-to-box redundancy. In order for the pair to operate with b2b one of the Ge interfaces needs to be used for a heartbeat to a Ge interface on the other 11503. With this configuration we are only left with 1 Ge interface per box. In order to achieve the desired result I am planning to trunk (preferably .1q) from Ge1/2 to a 3750 switch. I have applied what I believe to be the appropiate commands but the interface becomes unactive and reachable only via the local segment (I cannot ping outside of the local segment). Here are my configs on the css and the switch. Also, it has occured to me that the CSSs might requrie a full blown config in order for it to be able to accept and respond to ICMP. Please review and advise.
3750 SWITCH CONFIG
interface GigabitEthernet1/0/14
description css1 ge1
switchport trunk allowed vlan 200,300,400,500,600,700
switchport mode trunk
interface GigabitEthernet1/0/15
description css2 ge1
CSS 11503 CONFIG
qw-css-1# sho run
!Generated on 11/04/2004 21:10:52
!Active version: sg0740004
configure
!*************************** GLOBAL ***************************
sntp server 10.0.0.10 version 1
cdp run
vrrp-backup-timer 15
ip redundancy
app session 1.1.1.1
app
dns primary 10.0.0.10
dns suffix admin.qw.franklin.edu
ftp-record DEFAULT_FTP 10.0.0.11 ftp des-password ef1gschehdkc6cza
!************************* INTERFACE *************************
interface 1/1
trunk
vlan 200
vlan 300
vlan 400
vlan 500
vlan 600
vlan 700
vlan 800
interface 1/2
bridge vlan 2
!************************** CIRCUIT **************************
circuit VLAN2
ip address 1.1.1.2 255.255.255.0
redundancy-protocol
circuit VLAN700
redundancy
description "Console *RILO* VLAN"
ip address 10.0.5.40 255.255.255.0
circuit VLAN600
redundancy
description "Remote VLAN"
ip address 10.0.4.40 255.255.255.0
circuit VLAN500
redundancy
description "Active Directory VLAN"
ip address 10.0.3.40 255.255.255.0
circuit VLAN400
redundancy
description "Students VLAN"
ip address 10.0.2.40 255.255.255.0
circuit VLAN300
redundancy
description "Courses VLAN"
ip address 10.0.1.40 255.255.255.0
circuit VLAN200
description "Admin VLAN"
qw-css-1#
9 Replies 9
seilsz
Level 8
Level 8
I actually did see that document...I actually have the PDF downloaded on my PC. I was, however, a bit confused on why some of the things in the document were configured. Are the *bridge state*, *bridge pathcost* and *bridge priority* commands required or are they optional commands?
Also, I think one of my biggest concerns is with my current config (posted above) should I be able to ping the IPs on the circuits?
Thanks for all the help guys.
bc
Your CSS trunk configuration looks fine. The bridge state, pathcost and priority commands are optional.
I don't see any routes configured in your CSS. What is the IP address you are trying to ping the circuits from?
~Zach
Routes...ahh...we might be on to something here. Actually anywhere I try to ping from I can't seem to get anything. I am only able to get into the box via the mgmt ip. This IP is on the same segment as a linux box that I ssh to. So, for these circuits to work, do you think that I need a default route for each circuit defined? Thanks again for the help Zach.
bc
The CSS needs to understand how to get back to the source of the traffic it is receiving. Whether that is a default route or something more specific really depends on your topology/routing policy.
For devices outside the CSS, they will need routes pointing to the circuit and/or content VIP addresses. How many and of what type, again, depends on your design.
If you want to post a diagram or some additional information, I'm sure we could figure it out.
~Zach
pknoops
Level 7
Level 7
I would agree that you need to have atleast one default route on the CSS to make things work.
You may also want to add "default vlan" to the GE port in question as this is necessary.
Pete..
Two things:
First, I added the appropriate statics to the box and it still seems like a now go.
Secondly, I've got some things to do but I'm going to post a Visio after a bit so you can all know what I'm dealing with.
Thanks again!
bc
What does a show phy and show int show? Are the interfaces up?
I don't see the switchport command under the 3750 interface. You should specify it as a switchport.
well another thing about the Switch.
In my opinion the default vlan which is 1 if nothing is configured is not permitted on the trunk which causes trouble in my opinion. In the case you have a diffrent vlan as default vlan you've to configure this on the switch and on the CSS so that every device knows which is the default vlan.
Cheers,
Joerg
