Problem with Syncing configuration to our CSM
danielseely
Recently we have had problems syncing between our pair of redundant CSM's.
Here is the behavior we observe when we run the command on one of our 6500.
! config 6500-2
module ContentSwitchingModule 2
ft group 1 vlan 4
  priority 10 alt 20
! config 6500-1
ft group 1 vlan 4
6500-2#hw-module csm 2 standby config-sync
After we run this command on 6500-2 the log shows that the sync happens and the CSM config is deleted on 6500-1 and then nothing happens.
Here is the exact logout on each of the 6500.
6500-2(ACTIVE)
May 28 17:45:11.353 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Active: Bulk sync started
May 28 17:45:11.369 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Active: Sending configurations to Standby CSM, this may take several minutes!
May 28 17:45:12.749 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Active: Sending configuration to Standby CSM
May 28 17:45:14.869 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Active: Sending configuration to Standby CSM
May 28 17:45:24.345 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Active: Manual bulk sync completed
May 28 17:45:24.349 est: %CSM_SLB-4-REDUNDANCY_WARN: Module 2 FT warning: Config Sync does not save Standby running-config to startup-config
6500-1(STANDBY)
May 28 17:45:17.088 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Standby: Started clearing configuration
May 28 17:45:17.088 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Standby: Completed clearing configuration
May 28 17:45:17.096 est: %CSM_SLB-4-REDUNDANCY_WARN: Module 2 FT warning: Standby: Config Sync does not save running-config to startup-config
May 28 17:45:17.100 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Standby: Previous configuration are being deleted from supervisor
May 28 17:45:17.104 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Standby: Previous configuration being deleted on Standby CSM
May 28 17:45:17.104 est: %CSM_SLB-6-REDUNDANCY_INFO: Module 2 FT info: Standby: New configuration are being configured
As you can see the configuration ends up being deleted from the STANDBY and the new configuration never gets configured to 6500-1(STANDBY).
We have tried replacing the SUP engine however this did not help.  We will try to replace the CSM next.  If anyone can shed some light on why this would happen I would apreciate it.
gaursin2
pls check for IOS bug CSCtd09117  and CSCsx64648
