problems upgrading csm code...
triplecap
Community Member
Just got the CSM installed and was trying to upgrade the code level to 4.2.
The configuration guide for 4.2 says you can upgrade via sup-bootflash, pcmcia card or tftp. Haven't tried tftp yet, but here's the problems I'm having so far:
The syntax for upgrading via sup-bootflash is "upgrade 127.0.0.zz csm_image.bin", where zz is 12 if the sup engine is in slot1 or zz is 22 if the sup is in slot2. Since I'm running a sup720, I have no choice but to have the sup720 installed in slot 5 or 6. What number do I use for zz then?
If I try to upgrade via pcmcia, one of the first steps is to enable the tftp server to supply the image to the flash card with the command "tftp-server slotx:csm_image.bin" However, the slotx option is not available to me (running IOS 12.2(18)SXD5).
How then do I upgrade???
Thanks in advance,
Eric
Gilles Dufour
Eric,
The sup720 in slot 5 will be 127.0.0.51 and in slot 6 127.0.0.61.
You can do a telnet to one of these addresses from the sup and you will see where you get.
Then, the sup720 does not have slot:, but disk: [at least mine does 🙂 ]
gdufour-cat6k-2(config)#tftp-server ?
bootflash: Allow URL file TFTP load requests
const_nvram: Allow URL file TFTP load requests
disk0: Allow URL file TFTP load requests
disk1: Allow URL file TFTP load requests
null: Allow URL file TFTP load requests
sup-bootflash: Allow URL file TFTP load requests
sup-image: Allow URL file TFTP load requests
sup-microcode: Allow URL file TFTP load requests
system: Allow URL file TFTP load requests
Do a dir disk0: or disk1: or a sho flash all to locate the file.
If nothing works, simpy configure a vlan on the CSM and upgrade via TFTP from a server.
Gilles.
Gilles,
The 127.0.0.51 & 61 addresses solved the problem. I also was able to upgrade via disk0: - not sure why I didn't see that option the first time around with "tftp-server ?"
Thanks!
Eric
