Product ID data.
Gilles Girard
Community Member
Is there a source available to find product based on their ID.
The Serial # tool is great for switch and routers but I have an inventory to sort where I have a lot of power supply and fans that I need to identify if they are standard or reverse flow.
The cherry on the sundae would be to have a compatibility reference for those components.
Thank you.
Gilles
Gilles Girard
Community Member
If others needs the info:
1- Loggin to Cisco Commerce @ https://apps.cisco.com/Commerce/guest
2- Go to: Search by Product Family
3- Select Product Description or SKU
4- Enter the ID in search field.
Cisco provided the following aternative:
-Ask to partner or point of sales, you could locate Point of Sales/Cisco Partner through this link: http://locatr.cloudapps.cisco.com/WWChannels/LOCATR/openBasicSearch.do.
