Showing results forĀ
Search instead forĀ
Did you mean:Ā
Radware Failover issue
sudhir.rai
Community Member
Hi all,
Currently i am having two radware Web Server Director Pro AS, Cookie Persistency (512 farms).
While configuring VRRP through APsolute insite we got an error  while copying configuration from master to backup.
Kindly suggest the solution to proceed further . Below is the error :
There is no corresponding display value in MIB label  rsWSDServerBackupPreemption for value: #InvalidValue (0) (valid values are: disable,enable)
Please suggest what is the issue !
Marko Leopold
Level 6
Level 6
Although i guess radware is not a topic in CSC, i would suggest it is some error with the MIB. maybe you have on older version of the MIB inside your APsolute insite. The error seems to say that your Application is trying to change a MIB-value with the wrong things.
Thanks for the information.
Can you  suggest me the version of APsolute insite which is in accordanve with WSD
Current Version is :
WSD IOS Version is   8.16.13
APsolute version is 2.70.17DL
