RDP and WAAS urgent
fast5658659
Hi All,
         I have a weird issue. I am using inline method we have two sites. One is DC and Other is Branch.
I have put two WAVE 274 at DC, one is acting as CM
The third one is at Branch office.
Optimization is working fine but I am not able to rdp to branch pc from DC. rdp from branch to DC is working ok.
Here is an output from DC WAE
Connection Id:            20
    Peer Id:                  00:0f:fe:ff:91:dc
    Connection Type:          EXTERNAL CLIENT
    Start Time:               Wed Oct 27 22:50:40 2010
    Source IP Address:        192.168.0.10
    Source Port Number:       36781
    Destination IP Address:   192.168.101.124
    Destination Port Number:  3389
    Application Name:         Remote-Desktop
    Classifier Name:          MS-Terminal-Services
    Map Name:                 basic
    Directed Mode:            FALSE
    Preposition Flow:         FALSE
    Policy Details:
           Configured:        TCP_OPTIMIZE
              Derived:        TCP_OPTIMIZE
                 Peer:        TCP_OPTIMIZE
           Negotiated:        TCP_OPTIMIZE
              Applied:        TCP_OPTIMIZE
    Accelerator Details:      None
                                    Original            Optimized
    Bytes Read:                           19                    0
    Bytes Written:                         0                   19
If I put DC WAE into bypass mode RDP works fine
any ideas ?
fast5658659
Same is the case with CIFS I am not able to open file share as well from DC. When I turnoff the optimization on CIFS / Ms terminal services on DC-WAE it works fine
Any clue?
Problem solved I was missing 'ip inspect waas enable' command on edge router
