redirect incoming port 80 to another vip
d-olds
I am doing ssl termination on a 11503. sessions start fine and data flows fine until the web servers sitting behind the css start supplying fully qualified url's "http://yada...com" to the clients, so the incoming request are going directly to the server via a different session and then the browser gets the mixed-secure/unsecure message, but works fine. Can I intercept and send a redirect back to the browser to go to https://vip when it comes in on 80? Iplanet says this cannot be changed on the webserver.
thanks
Dennis
Gilles Dufour
you need the urlrewrite command that is available in the new 7.20 version.
This command is similar to the existing urlrewrite command on the SCA.
Gilles.
The server isn't using 302 redirects, the fully qualified urls are in the web pages.
I was able to get it do work, but I would need to have a rule/service for every url requested to get it to work.
is there a way to get the url "http://x.com/GOHERE" appended in the redirect https://x.com/GOHERE" dynamically?
*bad: The ssl_redirect needed an ip address outside of the box, I used the ip on a workgroup switch to keep the service alive. I couldn't point it directly at the vip.
here is the config.
!Generated on 04/02/2003 08:29:39
!Active version: sg0710003 "cisco 11503"
configure
!*************************** GLOBAL ***************************
x
ssl associate rsakey x x
ssl associate cert x x
ssl associate dsakey x x
ssl associate dhparam x x
x
!************************* INTERFACE *************************
interface 1/1
trunk
phy 1Gbits-FD-no-pause
vlan 15
interface 1/2
trunk
vlan 15
interface 2/1
bridge vlan 15
phy 100Mbits-FD
!************************** CIRCUIT **************************
circuit VLAN15
ip address 168.183.x.44 255.255.255.192
!*********************** SSL PROXY LIST ***********************
ssl-proxy-list x
ssl-server 1
ssl-server 1 vip address 168.183.x.43
ssl-server 1 rsakey x
ssl-server 1 rsacert x
ssl-server 1 cipher rsa-with-rc4-128-md5 168.183.x.43 81
active
!************************** SERVICE **************************
service css1
ip address 168.183.x.47
protocol tcp
keepalive type http
port 81
active
service css2
ip address 168.183.x.46
protocol tcp
port 81
keepalive type http
active
service ssl_Module1
type ssl-accel
keepalive type none
slot 3
add ssl-proxy-list x
active
service ssl_redirect
type redirect
no prepend-http
port 443
ip address 168.183.x.49
redirect-string https://x.com
active
!*************************** OWNER ***************************
owner securemail
content sm-http
url "/*"
protocol tcp
port 80
redirect "https://x.com"
add service ssl_redirect
active
content sm-ssl
application ssl
protocol tcp
port 443
add service ssl_Module1
active
content sm81
protocol tcp
port 81
add service css1
add service css2
active
