redirecting traffic other than http to a proxy using WCCP
miwitte
Level 4
Level 4
It appears that WCCP V2 can be used to redirect traffic other than port 80. I want to be able to do this to a Linux Squid proxy box. We have sucessfully redirected port 80 traffic and are now looking to do the same for other traffice(HTTPS, 8080, FTP, IM, etc)
I just saw some posts that looked applicable;
Questions;
1) Would I create a service group for each protocol I wanted to redirect, and use an extended access list using the port or service that i wanted to redirect?
2) In a previous post it looks like you need to know the group # of what you want to redirect (ex 60 for FTP) for the content engine. Is this the case or can you use access list to specify the port or service you want to redirect?
3) If you can use just group numbers, is there a list of what numbers you can and cannot use? I know the allowed numbers are 0 to 99. Also if you can use specific numbers for the services are there any cross references? Is this something that is configured on the content engine?
Thanks in advance.
Not applicable
