Redundancy is not supported between an ACE module and an ACE appliance operating as peers
Anatoly Fedchik
Could you explain me what is that mean-"Redundancy is not supported between an ACE module and an ACE appliance operating as peers"
I'm designing network in which I plan to use  ACE-4710-0.5F-K9 appliances.
Thanks in advance
sivaksiv
If you have 2 ACE appliances then you should be good to setup redundancy between them.
The ACE  Module is for Cisco Catalyst 6500 Series Switches and Cisco 7600 Series Routers.
http://www.cisco.com/en/US/products/ps6906/index.html
Siva
