Installation of Cert and key for an appliation
Hi All,
Can any body help me to know the best practices to be followed while installing a cert and key for an URL?
It would be very help if you could share any link to learn about installation of cert and key.
Thiyagarajan
chrhiggi
Level 3
Level 3
Hello Thiyagarajan-
  Configuration Links:
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Configuration_Examples_--_SSL_Configuration_Examples#Example_of_an_SSL_Termination_Configuration
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3045.shtml
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c6f37.shtml
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/vA4_1_0/configuration/ssl/guide/sslgd.html
You want to install 1 cert/key pair per domain.  If you have a multi-domain or wildcard cert, you may need less.
The easiest way to install single certificates is to use the terminal and cut-paste them into the screen:
host1/Admin# crypto import terminal MYCERT.PEM
Enter PEM formatted data ending with a blank line or "quit" on a line
by itself
--------BEGIN CERTIFICATE-----------------------
MIIC1DCCAj2gAwIBAgIDCCQAMA0GCSqGSIb3DQEBAgUAMIHEMQswCQYDVQQGEwJa
QTEVMBMGA1UECBMMV2VzdGVybiBDYXBlMRIwEAYDVQQHEwlDYXBlIFRvd24xHTAb
BgNVBAoTFFRoYXd0ZSBDb25zdWx0aW5nIGNjMSgwJgYDVQQLEx9DZXJ0aWZpY2F0
aW9uIFNlcnZpY2VzIERpdmlzaW9uMRkwFwYDVQQDExBUaGF3dGUgU2VydmVyIENB
MSYwJAYJKoZIhvcNAQkBFhdzZXJ2ZXItY2VydHNAdGhhd3RlLmNvbTAeFw0wMTA3
-----------END CERTIFICATE------------------------
quit
The easiest way to import many at once is to use the SFTP bulk import:
host1/Admin# crypto import bulk sftp 1.1.1.1 JOESMITH /USR/SSLFiles/*.PEM
Initiating bulk import. Please wait, it might take a while...
Connecting to 1.1.1.1...
Password: password
Bulk import complete. Summary:
Network errors:                                                        0
Bad file URL: 0
Specified local files already exists:                                                       0
Invalid file names:                                                        1
Failed reading remote files:                                                        5
Failed reading local files:                                                        0
Failed writing local files:                                                        0
Other errors:                                                        0
Successfully imported: 16                                                       10
host1/Admin#
