Removing Connection statistics - WAAS 4.1a
How do you remove connection stat's? I would image removing a file, but which one? I'm working in a lab environment and it would be helpful to remove this info to get fresh data.
dstolt
Are you talking about on the CM? I go into the System/Configuration and set the "System.monitoring.recordLimitDays" to 0 and then set it back to the default. That should clear all the statistics on the CM GUI (not the device CLIs) and give you a fresh start.
Hope that helps,
Dan
