Reset Conf. Register on SSL Daughter Card
bradleyordner
Level 3
Level 3
HI,
Was wondering if anyone knows how to reload a SSL Daughter Card on the CSM-S ?
When we SSH or session to it , it displays an error that we can not reload card from a Telnet line and we should change the Configuration Register.
Is it better to possibily reload the entire unit?
BRad
Daniel Arrondo Ostiz
Hi Brad,
To reboot the SSL daughter card, you have to reboot the full module from the switch using the "switch# hw-module module reset" command
Daniel
