Rserver/Vip same network
Don Brack
Community Member
This may sound like a silly question but can I configure the rservers and the vip address on the same network? If so does anyone have a example config?
NAT, policy, etc
9 Replies 9
Don Brack
Community Member
Sorry this is for a ACE 4710.
Hi Don,
Yes you should be able to configure this, this setup is called Direct server return, since the client will be directly reachable from the server, only incoming connections comes through the vip and the return connection is directly established from the server to the client bypassing the ace.
you can find further information on this configuration (Asymmetric Server Normalization) here :
http://snippets101.blogspot.com/2008/08/asymmetric-server-normalization-on.html
Abijith
Surya ARBY
Level 10
Level 10
If you need don't need to keep the source ip address for log purposes, use source NAT
If you need to keep the source ip address for log purposes :
- for HTTP insert the source IP into the header and use source nat
- otherwise use DSR.
Source NAT config
policy-map multi-match DOMINO-WEB-PM
  class DOMINO-WEB-VIP
    nat dynamic 1 vlan 3
    loadbalance vip inservice
    loadbalance policy DOMINO-WEB-CLASSIFY
    loadbalance vip icmp-reply
    appl-parameter http advanced-options http_parameter_map
  exit
exit
interface vlan 3
  ip address 10.123.3.X 255.255.255.0
  alias 10.123.3.X+1 255.255.255.0
  peer ip address 10.123.3.X+2 255.255.255.0
  access-group input PERMIT-ALL
  nat-pool 1 10.123.3.245 10.123.3.245 netmask 255.255.255.0 pat
  no shutdown
and apply the service policy
Thanks for quick response....
I have many services configured with the VIP on a different network then the Rservers, and having no issues.
Now I'm having issues because the VIP and Rserver is on same network. Here is my config.
I cannot ping or access the VIP..
Thanks Again for all help..
probe icmp icmp
  ip address 10.201.13.61
  interval 5
  passdetect interval 60
probe tcp episfdasp-80-probe
  port 80
  interval 5
  passdetect interval 5
  connection term forced
  open 1
rserver host w8v-episfdasp1
  ip address 10.201.13.10
  conn-limit max 4000000 min 4000000
  inservice
rserver host w8v-episfdasp2
  ip address 10.201.13.11
  inservice
serverfarm host episfdasp-443
  transparent
  predictor leastconns
  probe episfdasp-443-probe
  probe icmp
  rserver w8v-episfdasp1
    inservice
  rserver w8v-episfdasp2
    inservice
sticky ip-netmask 255.255.255.255 address source episfdasp-443-sticky
  replicate sticky
  serverfarm episfdasp-443
class-map match-all episfdasp-443
  2 match virtual-address 10.201.13.61 tcp eq https
policy-map type loadbalance first-match episfdasp-443-policy
  class class-default
    sticky-serverfarm episfdasp-443-sticky
    nat dynamic 1 vlan 15 serverfarm primary
policy-map multi-match client-vips
  class episfdasp-443
    loadbalance policy episfdasp-443-policy
    loadbalance vip icmp-reply active
interface vlan 15
  description dmz network
  ip address 10.201.13.8 255.255.255.0
  no normalization
  mac-sticky enable
  no icmp-guard
  access-group input inbound
  nat-pool 1 10.201.13.240 10.201.13.245 netmask 255.255.255.0 pat
  service-policy input remote_mgmt_allow_policy
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.201.13.1
Why do you use the "transparent" keyword ?
Probably bcause I'm reading to much info on a simple problem.
This is what I read:
The transparent command prevents the ACE to make a destination NAT, sending the packet as to the real server.
Using the transparent option on the serverfarm is a non standard design which should be only used when using IDS / FW load balancing.
Remove the transparent keyword (eventually issue a shut / no shut on the interface or reboot the appliance to be sure to flush the whole memory and reinit all the processes)
Then put a PC in the VLAN15 or try to access the VIP from a server located into that VLAN.
At least the VIP should reply to a ping.
Just let me know if you need further assistance.
To resolve this I had to remove and add:
interface vlan 15
  no normalization
  mac-sticky enable
  no icmp-guard
  -----service-policy input remote_mgmt_allow_policy----removed
-------service-policy input clients-vips---added
  no shutdown
