Same Context different VIPs and Polices
iaa_cisco
Community Member
Howdy!
I have a question about if it posable to configure different VIPs and configuration parametrs(class-maps,policy-maps and other parameters)  for deferent server-farms under same Virtual Context?
For example:
I want to do Loadbalncing for some HTTP application and configure all needed setings for that. On the other hand I want to do Loadbalancing for Exchange app. within different network with different VIP and server-farm but under same CONTEXT.
I don't concern about security and resources.
Can I do that?
asharmav
Level 5
Level 5
Yes, You should be able to do that, you can have multiple vips, multiple paramaeter maps, multiple class maps , multiple policy maps , multiple vlans all in the same context.
I need to make defferent Domains in same context and specifie the objects that I want to associtiate with Domain right?
Yes you should be able to make different domains, and you can add any object under that context to that domain.
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_%28ACE%29_Troubleshooting_Guide_--_ACE_Resource_Limits
The above link provides the Config limits for ace. Please refer to it.
Thank you
