sticky or not ?
tzografos
I have the following configuration on an ovh loadbalancer
access-list ANY line 8 extended permit icmp any any
access-list ANY line 16 extended permit ip any any
probe tcp PROBE_TCP
  interval 30
  passdetect interval 60
rserver host app5_im
  ip address 172.16.0.2
  conn-limit max 50000 min 40000
  inservice
rserver host app6_im
  ip address 172.16.0.3
  inservice
serverfarm host farm_im
  predictor leastconns
  probe PROBE_TCP
  rserver app5_im
    inservice
  rserver app6_im
    inservice
parameter-map type http HTTP_PARAMETER_MAP
  persistence-rebalance
sticky http-cookie CookieACE StickyGroup1
  cookie insert
  timeout 720
  replicate sticky
  serverfarm farm_im
class-map match-all L4-WEB-IP
  2 match virtual-address 46.105.181.161 tcp eq www
class-map type management match-all REMOTE_ACCESS
  2 match protocol ssh any
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
  class REMOTE_ACCESS
    permit
policy-map type loadbalance http first-match WEB_L7_POLICY
  class class-default
    sticky-serverfarm StickyGroup1
    insert-http x-forward header-value "%is"
policy-map multi-match WEB-to-vIPs
  description Ties L4-WEB-IP class-map, WEB_L7_POLICY maps together and applies HTTP_PARAMETER_MAP. Uses NAT.
  class L4-WEB-IP
    loadbalance vip inservice
    loadbalance policy WEB_L7_POLICY
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 2131
    appl-parameter http advanced-options HTTP_PARAMETER_MAP
interface vlan 1203
  ip address 46.105.181.170 255.255.255.240
  alias 46.105.181.169 255.255.255.240
  access-group input ANY
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  service-policy input WEB-to-vIPs
  no shutdown
interface vlan 2131
  ip address 172.31.255.250 255.240.0.0
  alias 172.31.255.249 255.240.0.0
  peer ip address 172.31.255.251 255.240.0.0
  nat-pool 1 172.31.255.248 172.31.255.248 netmask 255.240.0.0 pat
  no shutdown
ft track interface  VLAN1203
  track-interface vlan 1203
  peer track-interface vlan 1203
  priority 5
  peer priority 50
on every server I have the following cookie.php file
<html>
<head>
<?php
$n = 'CookieACE';
if( ! $_COOKIE["$n"]) {
$cookie=rand(1,10000);
echo '<meta http-equiv="Set-Cookie" content="'.$n.'='.$cookie.'; path=/" />';
</head>
<body>
Hello from SERVERx   <!-- x is 1 for server1 and 2 for server 2-->
<?php
if($_COOKIE["$n"])
echo "Got cookie: $n = $cookie";
else
echo "New cookie set: $n = $cookie";
</body>
</html>
unfortunately it seems not to work as I do not get stickyness, and the "show sticky database" is always empty.
Is there some thing wrong with this conf ?
Any help will be greatly appreciated
Surya ARBY
Level 4
Level 4
cookie insertion stickyness is not dynamic, there is static mapping between the cookie value and the back end server.
Also for browser based applications use a "browser expire" instead of a timeout 720.
When you're browsing the site, do you see the sticky cookie in the browser or when running a "live http header" or a wireshark ?
Well no, I am only using the cookie.php file that ovh provided in order to check that sticckyness exists.
Unfortunately it does not provide the output stated, but it does not allow me either to chenge servers on refresh.
That is if I get diverted to server5 then it stays there and does not redirect on refresh to server6. That might mean that I do have stickyness...
I am just checking to see why the ovh example does not produce the results stated.
Thanks again
