Session Persistence status help
shanemcanuff
Level 3
Level 3
I am new to Cisco ACE, I have a ACE 4710 MD running, I would like to know how can I know what session persistence is running on the ACE, I what to know if it is using soruce IP or any other persistence.
pablo.nxh
Level 8
Level 8
You can do a "show run sticky" in the context in question. From there you can check to what first-match policy it is implemented and run some other helpful "sticky" commands in case you're facing a problem with persistence.
__ __
Pablo
