set max-parse-length 8192 on ACE
fabio.marino
Level 5
Level 5
Hi all, I would like to know the meaning of 'set max-parse-length 8192' on ACE.
Looking at Cisco documenation I found:
"...You can set the maximum number of bytes to parse for generic protocols by using the
set max-parse-length command in generic parameter-map configuration mode.
You can set the maximum number of bytes to parse for generic protocols by using the set max-parse-length
command in generic parameter-map configuration mode....'
After that I got more confuse. Can please,  someone clarify what a set max-parse-lenght is? Thanks a lot.
krun_shah
Level 7
Level 7
In order for the payload inspection to function, you need to set an  appropriate max-parse-length. This is necessary to tell the parser how  much data to inspect in the payload, and by default it is set to 4096  bytes.
krun_shah
Level 7
Level 7
