Setting up additional load balancing on ACE 4710
santipongv
I recently deployed ACE 4710 to load balance traffic to a group of web servers. I would like to add additional server farm(s) with different applications on them to ACE 4710 for load balancing the traffic. How can I best achieve this goal? I currently use 3 interfaces out of 4 interfaces (Server Side interface, Client side interface, and Failover interface). Do I need to use my last interface to set up for the new VIP address for a new server farm? Is virtualized service a possible solution? Thank you in advance.
Gilles Dufour
You can configure trunking so that multiple vlans can exist.
Also note that the vip ip address does not have to belong to a subnet.
You could configure a static route on the upstream router pointing the traffic for the new vip to the interface ip address.
Gilles.
Do you mean that I can add a new VIP address to an existing interface and configure a static route on the upstream router as suggested?
I think I get your point. I will try and let you know. Thank you.
