Single CSM, load balanced ISA Firewall, how to route through
dojnetsup
Am trying to set up a single CSM with 2 load balanced ISA firewalls. Have seen the CCO information on how to do this, but can't get it to work correctly.
My setup is as follows:
Outside Server (Vlan 10)
IP 10.0.0.100
IP 10.0.0.1
Router (MSFC)
IP 192.168.79.1
CSM (Vlan 79) IP 192.168.79.4
ISA1 (.35) VIP (.50) ISA2 (.36)
CSM (Vlan 247) IP 192.168.247.4
ip 192.168.247.1
Router
IP 192.168.254.1
Inside Workstation (Vlan 903)
IP 192.168.254.100
If that makes any sense I am trying to connect between workstation and server and have the CSM determine which ISA to use (Load balanced)
I also have a requirement to use the ISA servers as a HTTP proxy so need to target the VIP address.
My main question, I think is around the routing. How should I set the routers to route the traffic through the network? Do I point to route to the ISA VIP or to the CSM Vlan address?
Current Config:
module ContentSwitchingModule 4
vlan 247 server
ip address 192.168.247.4 255.255.255.0
gateway 192.168.247.1
vlan 903 client
ip address 192.168.254.4 255.255.255.0
vlan 79 server
ip address 192.168.79.4 255.255.0.0
vlan 10 server
ip address 10.0.0.4 255.255.255.0
gateway 10.0.0.1
serverfarm FORWARD
no nat server
no nat client
predictor forward
serverfarm ISALB_IN2OUT
no nat server
no nat client
real 192.168.79.35
no inservice
real 192.168.79.36
inservice
serverfarm ISALB_OUT2IN
no nat server
no nat client
real 192.168.247.35
no inservice
real 192.168.247.36
inservice
serverfarm ISA_INSIDE
nat server
no nat client
real 192.168.247.36
inservice
real 192.168.247.35
inservice
serverfarm ISA_OUTSIDE
nat server
no nat client
real 192.168.79.35
inservice
real 192.168.79.36
inservice
serverfarm ROUTERS
no nat server
no nat client
real 192.168.247.1
inservice
real 192.168.79.1
inservice
real 192.168.254.1
inservice
real 10.0.0.1
inservice
sticky 1 netmask 0.0.0.0 timeout 120
vserver IN2OUT
virtual 192.168.254.0 255.255.255.0 any
vlan 247
serverfarm FORWARD
sticky 240
reverse-sticky 1
persistent rebalance
inservice
vserver ISA2SERV
virtual 10.0.0.0 255.255.255.0 any
vlan 79
serverfarm FORWARD
sticky 240
reverse-sticky 1
inservice
vserver ISA_10_7_50
virtual 192.167.79.50 any
vlan 79
inservice
vserver OUT2IN
virtual 0.0.0.0 0.0.0.0 any
vlan 903
sticky 240
reverse-sticky 1
inservice
vserver SERV2ISA
vlan 10
sticky 240
reverse-sticky 1
inservice
If I set the routers to point to an individual ISA address, traffic flows correctly (but only through the single ISA).
If I set the routers to direct to the Virtual address then nothing flows and no connections are made on the switch
I have tried pointing the routes to the CSM addresses without success
Any help with this would be greatly appreciated
Many Thanks
LP
Gilles Dufour
the CSM is connected to vlan 10.
So, your clients should use the CSM as default gateway.
If you want to use the MSFC, remove vlan 10 from the CSM.
Also, you have configured 2 default gateways.
You should not.
Have 1 default gateway only pointing to the MSFC on vlan 79.
Then, if there is still a problem, capture show commands to see if traffic hit the correct rules.
'sho mod csm X conns detail' and 'sho mod csm X vserver name detail'
Gilles.
Thanks for the reply Gilles
After your reply, I completely redesigned the scenario (closer to the proposed reality anyway) and with much effort & testing managed to make it work. I did this without implementing MSFC VLAN interfaces for the ISA Servers and added a router on the outside.
Please feel free to edit/debunk any of the following config, but at the moment this is working just fine.
FYI for others. Note there is probably some config here that is not strictly required, but is included because I was testing different configurations.
New design
Outside World PC (192.168.254.x)
Router - Outside interface
Router - Outer CSM Vlan 239. IP 10.20.228.1
I have not defined this as a MSFC interface. Have separate router
CSM Client Vlan 239. IP 10.20.228.4
CSM Server Vlan 236. IP 10.20.229.17. No Msfc
ISA1 (10.20.229.19) ISA2 (10.20.229.20).
ISA1 (10.20.230.19) ISA2 (10.20.230.20).
CSM Server vlan 247. IP 10.20.230.17. no MSFC
CSM Client Vlan 1400. IP 10.20.227.4
Router via MSFC Int 10.20.227.1
Inside Network PC 10.x.x.x
Routing:
on outside router
ip route 10.0.0.0 255.0.0.0 10.20.228.4
on MSFC
ip route 192.168.254.0 255.255.255.0 10.20.227.4
CSM Config
vlan 247 server
ip address 10.20.230.17 255.255.255.240
vlan 236 server
ip address 10.20.229.17 255.255.255.240
vlan 239 client
ip address 10.20.228.4 255.255.255.192
gateway 10.20.228.1
vlan 1400 server
ip address 10.20.227.4 255.255.255.192
route 89.0.0.0 255.0.0.0 gateway 10.20.227.1
serverfarm FORWARD
no nat server
no nat client
predictor forward
serverfarm INROUTER
nat server
no nat client
real 10.20.227.1
inservice
serverfarm ISALB_INSIDE
no nat server
no nat client
real 10.20.230.19
no inservice
real 10.20.230.21
inservice
serverfarm ISALB_OUTSIDE
no nat server
no nat client
real 10.20.229.19
no inservice
real 10.20.229.20
no inservice
nat server
no nat client
real 10.20.230.19
inservice
real 10.20.230.20
inservice
nat server
no nat client
real 10.20.229.19
inservice
real 10.20.229.20
inservice
! for csm arp only - not sure if required
serverfarm ROUTERS
nat server
no nat client
real 10.20.227.1
inservice
real 10.20.228.1
inservice
! still testing sticky config
sticky 1 netmask 255.255.255.255 address both
vserver CSM2IN
virtual 89.0.0.0 255.0.0.0 any
vlan 1400
serverfarm FORWARD
inservice
vserver CSM2OUT
vlan 239
serverfarm FORWARD
inservice
vserver IN2ISA
vlan 247
serverfarm FORWARD
no inservice
vserver IN2OUT
vlan 1400
sticky 5
inservice
vserver ISA2OUT
vlan 236
serverfarm FORWARD
inservice
vserver ISALB_INSIDE
virtual 10.20.227.10 any
vlan 1400
inservice
vserver ISALB_OUTSIDE
virtual 10.20.228.10 any
vlan 239
inservice
vserver ISA_IN
virtual 10.20.230.30 any
vlan 1400
inservice
vserver OUT2IN virtual 89.0.0.0 255.0.0.0 any
vlan 239
sticky 5
inservice
