SLB-PROBE: Packets were dropped
At this time, I have packet loss for some farms, browsing services anomalous.
The following error messages filled the device logs:
Show logg:
Mar 14 13:10:00: %CSM_SLB-6-RSERVERSTATE: Module 3 server state changed: SLB-NETMGT: TCP health probe re-activated server XX.XX.XX.XX:80 in serverfarm 'NAMESERVER'
Mar 14 13:10:12: %CSM_SLB-6-RSERVERSTATE: Module 3 server state changed: SLB-NETMGT: TCP health probe re-activated server
XX.XX.XX.XX:443 in serverfarm '
NAMESERVER'
Mar 14 13:10:57: %CSM_SLB-6-RSERVERSTATE: Module 3 server state changed: SLB-NETMGT: TCP health probe failed for server XX.XX.XX.XX:80 in serverfarm 'NAMESERVER' 1y14w: CSM3: SLB-PROBE: Packets were dropped. Reducing the number of health probes and/or increasing the probe interval may prevent this.
Mar 14 13:11:20: %CSM_SLB-6-RSERVERSTATE: Module 3 server state changed: SLB-NETMGT: TCP health probe failed for server XX.XX.XX.XX :443 in serverfarm 'NAMESERVER'
Mar 14 13:16:01: %CSM_SLB-6-RSERVERSTATE: Module 3 server state changed: SLB-NETMGT: TCP health probe failed for server XX.XX.XX.XX:443 in serverfarm 'NAMESERVER'
Mar 14 13:17:01: %CSM_SLB-6-RSERVERSTATE: Module 3 server state changed: SLB-NETMGT: TCP health probe re-activated server XX.XX.XX.XX:443 in serverfarm 'NAMESERVER'
Mar 14 13:21:07: %CSM_SLB-6-RSERVERSTATE: Module 3 server state changed: SLB-NETMGT: TCP health probe failed for server XX.XX.XX.XX:443 in serverfarm 'NAMESERVER' 1y14w: CSM3: SLB-PROBE: Packets were dropped. Reducing the number of health probes and/or increasing the probe interval may prevent this.
Can you help me?
What I need to do, for resolve this issue?
This could be a resource issue as well if you are exceeding the configuration limit for
probes cannot be handled by CSM.
If its one time issue and not impcating the services, then no need to worry. Else you
could raise a TAC case to review the config.
here is a bug that explains this behavior.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCea40924
Siva
5 Replies 5
sivaksiv
Looks like the the CSM is not able to reach the servers. Please check if the server is listening on the tcp port which CSM is probing. Else convert this to an ICMP probe.
Siva
Thanks for your reply.
All tcp probes are functional.
However we are having this error message in the logs.
What is the reason of this message?
There is anything we can do?
Thanks for all.
Siva
Ok Sivaksiv,
Thanks for all.
I will open a support case
vindeone222
Hello ,
I am also getting same issue can you please help me solve
Dec 4 13:18:39.204 gmt: %CSM_SLB-6-RSERVERSTATE: Module 3 server state changed: SLB-NETMGT: TCP health probe failed for server 172.30.140.75:0 in serverfarm 'CE_MANCHESTER'
