SNAT on routed mode.
lucas restrepo
i have a topology where i have to set up an ACE in routed mode with two context. one for service provider A and one for ISP B.
what i want to do is when i receive a request coming from service proveder A i would like to SNAT that request to de VIP with a specific IP of the servers LAN to hide the source IP of the cliente in that way a can receive the request on the server with a local IP and the resever can respond to that IP.
in the same way to handle traffic on the second ISP.
i have try to set up the configuration in the same way it would work in one arm but it has not worked out for me.
is there a guide to follow or if someone can help me whit this config.
best regards.
pablo.nxh
Level 3
Level 3
Hi Lucas,
Does your current NAT config like this?
class-map match-any ISP-1
  2 match virtual-address 20.20.20.10 tcp any
policy-map multi-match LB
  class ISP-1
    loadbalance vip inservice
    loadbalance policy ISP
    loadbalance vip icmp-reply active
    nat dynamic 7 vlan 10
interface vlan 10
  description Server VLAN
  ip address 10.10.10.1 255.255.255.0
  nat-pool 7 10.10.10.15 10.10.10.20 netmask 255.255.255.0 pat
  access-group input any
  access-group output any
  no shutdown
interface vlan 20
  description ISP VLAN
  ip address 20.20.20.1 255.255.255.0
  service-policy input LB
  no shutdown
__ __
Pablo
pablo.nxh
Level 3
Level 3
Hi Lucas,
  class ISP-1
interface vlan 10
  no shutdown
interface vlan 20
  no shutdown
__ __
Pablo
Hi Pablo.
you have been of great help this config worked out perfectly.
the was that the site had a redirect on http but the site has not been plibished on the dns server.
but the nat setup help me a great deal.
best regards.
