SNMP direct monitoring of WAE
Simone.Toniolo
Hi all,
I'm trying to understand if there is a way to directly monitor of some general parameters of a WAE via SNMP in order to integrarate the WAAS solution in our existing monitoring system (HPOV and MRTG for graphs).
We would like to monitor for example
- CPU
- memory
- # of TCP connection handled by the WAE
Thanks in advance
Simone
2 Accepted Solutions
aorugant
Hi Simone,
Did you go through this "Configuring SNMP monitoring" section in the below link  for WAAS?
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v421/configuration/guide/SNMP.html#wp1107077
This document gives all the information you need to configure SNMP for WAE devices.
This link also has links to download required MIB's.
Hope this helps.
Anil.
yang Lv
Dear Simone,
     may the attachment will help you.
5 Replies 5
aorugant
Hi Simone,
Hope this helps.
Anil.
Thanks it's a good starting point!
Simone
yang Lv
Dear Simone,
This is waht I'm looking for!!!!!
Many Thanks!
     Simone
Were you able to get the graphs to show up on MRTG?
If so, could you be so kind and upload your WAAS host template?
John
