SNMP for ACE Failover.
fariha zain
Level 3
Level 3
Hi Experts,
Could someone please let me know the SNMP settings for my ACE failover.
Query:-
When my active 4710 ACE load balancer fails for any reason(due to s/w or h/w)  and the second 4710 ACE load balancer  take over (becoming active), will there be a SNMP alarm send from the ACE?
If so, which SNMP alarm will that be and which SNMP settings need to be applied for this?
Thanks in advance. Appriciate your comment on this.
Fari
chrhiggi
Level 8
Level 8
Hello Fariha-
There is a MIB you can poll to get the current FT stats:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.254.1.10.1.1#oidContent
As well, you can set "snmp-server enable traps syslog" with "logging enable" and "logging history 5" which will send all syslog messages (including ft failover messaging) as a trap to your snmp server.
Chris Higgins
Hi Christopher,
I configured the SNMP but nothing is been seen on SYSLOG Server. But I am able to ping the syslog server from ACE as it is in the same subnet.
But the messeges are not getting recored to the syslog server. I reloaded the ACE and saw OID getting generated for link up/dow and restart but nothing been recorded on the syslog server.
Is this a bug?
Generating configuration....
Logging part config:
logging trap 3
logging history 4
logging host 10.10.10.5 udp/514
SNMP part config:
snmp-server host 10.10.10.5 traps version 2c private
snmp-server trap-source vlan 32
snmp-server enable traps snmp coldstart
snmp-server enable traps virtual-context
snmp-server enable traps license
snmp-server enable traps slb vserver
snmp-server enable traps slb real
snmp-server enable traps snmp authentication
snmp-server enable traps snmp linkup
snmp-server enable traps snmp linkdown
However, I don’t see the OIDs you mentioned.Alsothere is no incoming syslog message from any of the ACE load balancer IP addresses shown.
Anyhelp would be appriciated. Thanks in advance.
Fari
Hi Chris,
Can you help on this please?
SYSLOG server is pingable but no ACE messages are recoreded there.
thanks
Fari
Fari-
  configure "logging enable" on ACE - it should look like this:
logging enable
logging trap 3
logging history 4
Chris
