SSL config issue
michael.e.reid
Level 3
Level 3
I have configured a front end SSL connection to a single server, traffic hits the CSS on port 443, is decrypted and sent to the server on port 81.
When I look at the flows I can see the correct from of traffic, port 443 from my PC to CSS, sent to SSL module, then from SSL module to server on port 81. Traffic is sent back and eventually the CSS sends traffic to me on port 443.
Now, for some reason I get a 'Page cannot be displayed' message, however if I go to the server directly it works fine.
I have configured SSL many times and really don't think it is my config, can anyone suggest anywhere else to look ? Even on the client/server side ?
cheers,
Mike
michael.e.reid
Level 3
Level 3
As follow up, when I trace connections to server directly (works) and via CSS (fails) I see an encrypted alert from the CSS to the Client then the client resets the connection.
This is not seen on the client <> server direct trace so must be coming from the CSS to my PC ? Any thoughts ?
cheers,
Mike
