SSL Module initial config
carlsond
Level 2
Level 2
I am using a csm on a 6500 in Native mode and trying to get an SSL module up and running. I have done the initial configuration as shown in the docs, setting up a VLAN 2 on the MSFC and on the SSL module as admin, gateway is the ip address on the vlan interface, enabled telnet and a password but I can not telnet to the module. Does anyone have any ideas why telnet is not working?
Thanks.
carlsond
Level 2
Level 2
The trunking to the module was not working. Not sure why but a power outage and resetting the trunking seems to have fixed the problem.
