SSL module not able to handle hidden URI rewrites
strujillo
currently the ssl module integrated on a 11501 is not able to rewrite hidden(embedded) URIs on a webpage whereas the SCA used to. Is there a work around (i.e. script) ??
Gilles Dufour
the SCA is able to but at the cost of performance.
So we decided not to do it for the CSS.
The solution is to have a webserver correctly setup to use relative URI.
Ask you webadmin to correct the problem.
Gilles.
