ssl rewrite issue for IDM application
Yahshanulla S
We have IDM application with SSL offloading in ACE with action REWRITE statement. We are using IDM for both HTTP and HTTPS applications authentication. But we have problem for HTTP sites like after IDM authentication HTTP header will be rewrite as HTTPS.
HTTP VIP --> IDM VIP -->Converted to HTTPS because of action REWRITE
IDM VIP has the following config:
action-list type modify http REWRITE
  ssl url rewrite location ".*"
policy-map type loadbalance first-match LB-rtp-login-stg-S443
  class class-default
    sticky-serverfarm SG-rtp-login-stg-S80
    action REWRITE
    insert-http IS_SSL header-value "ssl"
But if we remove action REWRITE  then HTTPS applications are breaking after IDM authentication. How to fix this issue?
10 Replies 10
Yahshanulla S
Guys,
Any body is having any idea about this???
Can you show me your multi-match policy as well? I guess you have a different class for http and https. Are you using the same loadbalance policy for http and https?
Olivier
Yes. we have separate multi-match policy for HTTP and HTTPS IDM VIP.
policy-map multi-match GP-SUBPROD-01-VIP
class VC-rtp-login-stg-S80
    loadbalance vip inservice
    loadbalance policy LB-rtp-login-stg-S80
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 2513
    nat dynamic 1 vlan 2514
    connection advanced-options TCP_PARAM_MAP
class VC-rtp-login-stg-S443
    loadbalance policy LB-rtp-login-stg-S443
    appl-parameter http advanced-options http_paramater_map
    ssl-proxy server SO-rtp-login-stg-S
I assume you didn't apply the rewrite action to the LB-rtp-login-stg-S80 policy. Do you maybe have some network captures exhibiting the problem?
Olivier
Well. the problem with only HTTPS( VC-rtp-login-stg-S443), As i explained before. This is IDM application(VIP) and we need to use HTTPS only as this is internet based. So the problem with only if other HTTP application gets authenticated with this IDM HTTPS VIP then the result is HTTPS (original request was HTTP).
Application (1) HTTP VIP --> IDM VIP -->Converted to HTTPS of Application (1)  because of action REWRITE
I hope you understood the problem.
Adding the screenshots
Hi oliver,
Do you have any suggestion
You basically need to rewrite the action-list so that it doesn't match
http://stagesupport.netap.com. Currently it is matching everything.
You should try to have a sniffer trace on the server side so that you can confirm the URL present in the Location header of the http redirection
Olivier
What do you want to put exactly under action list. Please give me some example.
Just have a look at this:
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3045.shtml
In the example, ACE is configured to rewrite location headers matching www.cisco.com only. You should do the same: have a restricted list of urls that need to be rewrite in http redirections.
Olivier
