SSL Termination Not Working
krishnadas.R_2
I have tried configuring SSL termination on ACE. soft ver is Version 3.0(0)A1(4a)
Connectivity was working fine with HTTP and the website was accessible from the Internet. After I put the SSL configs, the connectivity is not working, browser is throwing an error "Secure Connection Failed" "(Error code: ssl_error_rx_record_too_long)"
I am using a trial certificate from thawte for testing. Attached the running-config and the statistics.
Any help/advice is really appreciated.
kris
7 Replies 7
jason.espino
Hello kris,
Looking at your configuration your layer 4 class-map does not define/allow HTTP connections to establish to the vip address.
class-map match-all ERDMZ80
3 match virtual-address 10.1.151.100 tcp eq http
class-map match-all ERDMZ443
3 match virtual-address 10.1.151.100 tcp eq https
Regarding your SSL configuration it looks correct if the cert is self-signed, but you can also try to separate the configuration for HTTP and HTTPS traffic for the same VIP.
policy-map type loadbalance first-match ERDMZ-VIP
class class-default
sticky-serverfarm ERDMZ-STICKY
policy-map multi-match ERDMZ-POLICY
class ERDMZ80
loadbalance vip inservice
loadbalance policy ERDMZ-VIP
loadbalance vip icmp-reply
class ERDMZ443
ssl-proxy server ERproxy-1
- Jason
Hi Jason,
Many Thanks for taking time in looking into the configs.
I have separated the configs for HTTP and SSL, however it is not working.. I am thinking of installing a new trial certificate from some other CA, shall update you the result.
Kris
ciscocsoc
Level 4
Level 4
Hi Kris,
I'd normally expect to see a chaingroup with the Thawte CA and any intermediate certificates. Or is this test certificate self-signed?
Can you show the crypto file listing of the certificate(s) and key(s)? (sh crypto files)
Kind Regards
Cathy
HiCathy,
The certificate I am using is a trial one from Thawte.
Here is the output,
ICT_ACE1/ERzone# sh crypto files
Filename File File Expor Key/
Size Type table Cert
ER-Key.pem 887 PEM Yes KEY
ER-Cert.pem 1903 PEM Yes CERT
ICT_ACE1/ERzone#
I am not sure if the error is because I have installed a wrong certificate type? Do we need to install specific type of certificate for Cisco Devices? I have verified the that the certificate and key does match using crypto verify..
Waiting for the reply.
-Kris
Hi Kris,
You need to import Thawte Test CA Root.pem, add it to a chaingroup and then associate the chaingroup to the SSL server. The ACE needs to see the whole certificate chain.
Kind Regards
Cathy
Hi Cathy,
Thanks for the advice,
I have done it as you suggested, still the browser is showing the same error..
Attached is the current running config, pls have a look.
Kris
You shouldn't have an SSL server in the policy for HTTP traffic.
class ERDMZ80
ssl-proxy server ERproxy-1 <---delete
The error indicates an issue with the FQDN so you need to check the DNS name against the name you quote when generating the certificate.
Cathy
