SSL/TLS Handshake Failure with SSL Termination
xiaolonguk
Guys
Im wondering if you can help, I have two ACE 4710 configured in FT with 3 contexts, running bridged mode. Everything is working fine, however I cant seem to get SSL working in ssl proxy/termination mode.
When i do a show stats crypto server, I can see that the client has attempted to connect, but there is an SSL/TLS handshake failure, further down the screen it tells me there have been numerous SSL alert INTERNAL_ERRORs.
If i look at the service-policy I get N number of hits, and N number of dropped connections.  Ive no idea where this is going wrong.
At the moment the config on the context is dirt simple, so clearly im missing something
serverfarm host CUSTxxx-vFARM
  predictor reponse app-request-to-resp samples 4
  probe CUSTxx-HTTP-PROBE
   rserver SCEXTWB01 80
    inservice
  rserver SCEXTWB02 0
    inservice
exit
sticky http-cookie SessionID CUSTxxx-vFARM-STICKY
  cookie insert browser-expire
  timeout 1800
  replicate sticky
  serverfarm CUSTxxx-vFARM
exit
rserver redirect REDIRECT-TO-HTTPS
  webhost-redirection https://%h%p 301
inservice
action-list type modify http CUSTxxx-HTTPS-REWRITE
  ssl url rewrite location ???? sslport 443 clearport 80
ssl-proxy service CUSTxxx-SSL-SERVICE
  key CUSTxxx-key.pem
  cert CUSTxxx-cert.pem
serverfarm redirect REDIRECT-vFARM
  rserver REDIRECT-TO-HTTPS
inservice
class-map match-all CUSTxxx-HTTP
  2 match virtual-address ???? tcp eq 80
exit
class-map match-all CUSTxxx-HTTPS
  2 match virtual-address ???? tcp eq 443
exit
policy-map type loadbalance http first-match CUSTxxx-HTTPS-POLICY
  class class-default
  action CUSTxxx-HTTPS-REWRITE
  sticky-serverfarm CUSTxxx-vFARM-STICKY
policy-map type loadbalance first-match REDIRECT-TO-HTTPS-POLICY
  class class-default
    serverfarm REDIRECT-vFARM
policy-map multi-match VIP-POLICY
  class CUSTxxx-HTTP
    loadbalance vip inservice
    loadbalance policy REDIRECT-TO-HTTPS-POLICY
class CUSTxxx-HTTPS
    loadbalance policy CUSTxxx-HTTPS-POLICY
    loadbalance vip icmp-reply active
    ssl-proxy server CUSTxxx-SSL-SERVICE
    advanced-options tcp-parameter-map
    appl-parameter http advanced-options http-parameter-map
exit
Do you have ssl resource allocated for the context ?
Did you verify key and cert match ? (crypto verify ....)
Do you have a sniffer trace showing the problem ?
Gilles.
5 Replies 5
Pablo
The configuration looks in good shap, the only thing that seems to be misconfigured is the PAT for rserver SCEXTWB02, perhaps you hit the VIP and got a stuck to this server so any subsequent request will fail as port 0 is not your clear text TCP port
    inservice
  rserver SCEXTWB02 0
    inservice
exit
Once you've changed the port, clear the browser cache and try to connect again, if still no luck, paste the output of show service-policy VIP-POLICY and show serverfarm CUSTxxx-vFARM detail
__ __
Pablo
As requested.  If I run this up in firefox i get the following error.
Peer reports it experienced an internal error.
(Error code: ssl_error_internal_error_alert)
I can see from a show stats crypto server, that the client is trying to connect using TLS, and the cipher count does increase, however nothing works.  If i set an SSL parameter-map to nail this to SSL, i get a message about no common agreeable ciphers.
Context Global Policy:
  service-policy: VIP-POLICY
    class: CUST01-HTTP
      loadbalance:
        L7 loadbalance policy: CUST01-HTTP-POLICY
        Regex dnld status    : QUEUED
        VIP ICMP Reply       : ENABLED
        VIP State: INSERVICE
        Persistence Rebalance: ENABLED
        curr conns       : 0         , hit count        : 11
        dropped conns    : 0
        client pkt count : 1054      , client byte count: 54164
        server pkt count : 1405      , server byte count: 1940545
        conn-rate-limit      : -         , drop-count : -
        bandwidth-rate-limit : -         , drop-count : -
      compression:
        bytes_in  : 0                          bytes_out : 0
        Compression ratio : 0.00%
                Gzip: 0               Deflate: 0
      compression errors:
        User-Agent  : 0               Accept-Encoding    : 0
        Content size: 0               Content type       : 0
        Not HTTP 1.1: 0               HTTP response error: 0
        Others      : 0
        Parameter-map(s):
          http-parameter-map
          tcp-parameter-map
    class: CUST01-HTTPS
      ssl-proxy server: CUST01-HTTPS-SERVICE
      loadbalance:
        L7 loadbalance policy: CUST01-HTTPS-POLICY
        curr conns       : 0         , hit count        : 107
        dropped conns    : 2
        client pkt count : 427       , client byte count: 29603
        server pkt count : 3         , server byte count: 629
      compression:
                Gzip: 0               Deflate: 0
      compression errors:
        Others      : 0
        Parameter-map(s):
          http-parameter-map
          tcp-parameter-map
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: SCEXTWB01
       10.20.30.1:80         8      OPERATIONAL  0          6          0
         description          : -
         max-conns            : -         , out-of-rotation count : -
         min-conns            : -
         conn-rate-limit      : -         , out-of-rotation count : -
         bandwidth-rate-limit : -         , out-of-rotation count : -
         retcode out-of-rotation count : -
         average response time (usecs) : 0
   rserver: SCEXTWB02
       10.20.30.2:80         8      OPERATIONAL  0          4          0
         description          : -
         min-conns            : -
Gilles.
Giles
That got it, it was the resource call, howeevr what is confusing me is the resource class is defined for 20% of all the boxes capabilities.  I even created a seperate resource allocation for SSL and it didnt work.  If I remove the member allocation it works a treat.
How can I keep my resource allocations in place to protect the other contexts and still have ssl?
Weird, because you always need to be a member of some resource class.
Could you get a 'show resource usage' and 'show resource allocation'.
Gilles.
