Standby ACE not switching to active even when priority of active member is decreased due to vlan interface tracking.
I have 2 ace in active standby setup with FT configured, FT is working fine when i shut down the active box,at that time my standby becomes active.
I have enabled vlan interface tracking recently, when i shut down the interface from switch to which ACE is connected, i can see the priority is decreased in active ace than stanby but still stanby doenot become active at that time.
FT config:
ft interface vlan 2
  ip address 10.10.10.1 255.255.255.0
  peer ip address 10.10.10.2 255.255.255.0
  no shutdown
ft peer 1
  heartbeat interval 100
  heartbeat count 10
  ft-interface vlan 2
  query-interface vlan 421
ft group 1
  peer 1
  priority 150
  peer priority 145
  associate-context Admin
  inservice
ft track interface AAA
  track-interface vlan 421
  peer track-interface vlan 421
priority 50
  peer priority 5
ft track interface BBB
  track-interface vlan 431
  peer track-interface vlan 431
priority 50
  peer priority 5
8 Replies 8
Marko Leopold
Did you enable the "svclc autostate" command on your switch? It is required for vlan-tracking.
greetings.
The fact is the priority of active is getting decreased when i shut the vlan port from switch side.
It is that still i have to enable "svclc autostate" on switch.
Satish Bhat
Gilles Dufour
Set the priority of the tracked interface to 50.
Gilles.
As per my configuration ft track interace AAA & ft track interface BBB , peer track interface should be (ft vlan)vlan 2 or vlan 431 / 421.(interface vlan)
Can some one pls clear my doubt...?
Satish
I guess it depends on what you want to do. But usually you track on both sides the same vlan, if you want to track this interface.
sorry  had not seen you already had the priority.
What is the status of 'show ft track det' on each ACE when you shut down the interface ?
Gilles.
on primary ace:
LoadBalancer-1/Admin# sh ft group 1 detail
FT Group : 1
No. of Contexts : 1
Context Name : Admin
Context Id : 0
Configured Status : in-service
Maintenance mode : MAINT_MODE_OFF
My State : FSM_FT_STATE_ACTIVE
My Config Priority : 150
My Net Priority : 100
My Preempt : Disabled
Peer State : FSM_FT_STATE_STANDBY_COLD
Peer Config Priority : 145
Peer Net Priority : 145
Peer Preempt : Disabled
Peer Id : 1
Last State Change time : Thu Apr 29 03:30:14 2010
Running cfg sync enabled : Enabled
Running cfg sync status : Peer in Cold State. Error on Standby device when applying configuration file replicated from active
Startup cfg sync enabled : Disabled
Startup cfg sync status : Peer in Cold State. Startup configuration sync is disabled
Bulk sync done for ARP: 1
Bulk sync done for LB: 1
Bulk sync done for ICM: 1
Stanby Ace:
`show ft group detail`
FT Group : 1
No. of Contexts : 1
Context Id : 0
My State : FSM_FT_STATE_STANDBY_COLD
My Config Priority : 145
My Net Priority : 145
Peer State : FSM_FT_STATE_ACTIVE
Peer Config Priority : 150
Peer Net Priority : 100
Peer Id : 1
Last State Change time : Thu Apr 29 04:25:26 2010
Running cfg sync status : Error on Standby device when applying configuration file replicated from active
Startup cfg sync status : Startup configuration sync is disabled
Bulk sync done for ARP: 0
Bulk sync done for LB: 0
Bulk sync done for ICM: 0
The problem is that you disabled "preempt"
This is required for the standby to take over.
Actually, it is possible that preemot was automatically disabled because the 2 devices are not in-synch
Do a " show ft config-error" to detect the problem.
Gilles.
