Sticky problem with cookies on multiple servers
soumya.sarkar
We have the following general architecture:
Browser--> SecurityProxy(Auth) --> CSS (ssl frontend and backend) --> oneof[BEA ServerA1-A4 on machineA which use JSESSIONID_cookienameA, BEA ServerB1-B4 on machineB with JSESSIONID_cookienameB).
Not an unreasonable requirement. But we find that the stickiness is not retained across the two machines.
i.e., first accessing a url-A on machineA we stick to ServerA2 (e.g.), then accessing a url-B on machineB we stick to ServerB3(e.g.), however, reaccessing url-A, we are sent to ServerA3 on machineA, even though the browser and security proxy are faithfully forwarding both the cookies.
The sticky parameters are:
advanced-balance cookies
string prefix "def_clus_JSESSIONID="
string eos-char ";"
string operation hash-crc32
no persistent
Any help is appreciated. Thanks.
s.jankowski
Level 4
Level 4
Use arrow point cookies. If the cookie generated by the server is static, you can configure the CSS to look for
this cookie by configuring the content rule with the "advanced-balance cookies" parameter and configuring the services with "string " paramter.
