strange behaviour of http to https redirection
parveesm123
Level 3
Level 3
My client has a website and his request is some of the pages need to be redirected to https
for example his site is
rad1.booking.com and only these pages needed to be using https since it requires confidential entries
rad1.booking.com/ibe/passengerDetails.xhtml
rad1.booking.com/ibe/deliveryOptions.xhtml
rad1.booking.com/ibe/paymentMethods.xhtml
i have used both host redirection and ssl url rewrite using action list but both didnt gave me good result.
using redirection i have done follows
rserver redirect RS-redirect
webhost-redirection https://%h%p302
  inservice
serverfarm redirect SF-redirect
rserver RS-redirect
inservice
class-map type http loadbalance match-any CM-redirect
  2 match http url /ibe/*.*
policy-map type loadbalance http first-match L7-Policy-myweb
class CM-redirect
serverfarm SF-redirect
class class-default
sticky serverfarm Stick-my-webpage
When i used this , it didnt shown any http to https redirection , it always worked perfectly fine but just as usual http page
Second method
action-list
action-list type modify http AL-redirect
  ssl url rewrite location "rad1\.booking\.com"
class CM-redirect
action AL-redirect
class class-default
both didnt give me any solution which i am looking for..
am i doing something wrong  here?
thanks
Parvees
8 Replies 8
parveesm123
Level 3
Level 3
No one to assist here?
Does it work if you make a non cnoditionnal redirection ? (no class map matching a URL)
Your config seems to be ok to me.
Yes, i checked it with matching the source ip address in the L7 class map and it worked fine
And if you use
instead of
Hi Surya
it never get matched
       backup serverfarm : -
            hit count        : 0
            dropped conns    : 0
            hit count        : 0
            dropped conns    : 0
If i am changing the url match as following... it is working fine but the problem is all the pages in the website will get redirected to https ( as expected)
match http url /.*
How do we tweak the regex in ACE?
Did you also try this?
match http url /ibe.*
Siva
