TFO connection limit
ROMAN TOMASEK
Level 6
Level 6
is possible to configure connection limit for TFO or I have to buy more RAM? The customer has WAE574 with 3GB - here is connection limit 750. The customer has the following message: The TFO accelerator is overloaded (connection limit). So is possible to configure the number of connections to 800, or I have to upgrade WAE574 to 6GB?? Thank you.
show tfo detail
Policy Engine Config Item Value
State Registered
Default Action Use Policy
Connection Limit 750
Effective Limit 740
Keepalive timeout 3.0 seconds
Zach Seils
Level 11
Level 11
Roman,
The TFO connection limit is fixed based on the amount of RAM installed in the WAE.
Zach
Zach Seils
Level 11
Level 11
Roman,
Zach
