Throughput using FWSM and an ACE in same 6500
mbittman
I have been throw into the position of making a solution work that I had no part in ordering the hardware for. I have 2 6509s with an ACE module with the 16GBps license and an FWSM in each. From reading the datasheets for the ACE and FWSM, I find the ACE can handle 16Gbps of throughtput and the FSWM up to 5.5Gbps. Also, the ACE can handle 4 million concurrent connections while the FWSM can only handle 1 million. My question is this. Does it even make sense to use the FWSM at all? It doesn't seem to offer any feature over the FWSM and from what I can tell, I'm going to have to use either the ACE or the FWSM in transparent mode to be able to use both of them.
Not applicable
What documentation did you read that states that if you use an ACE with a FWSM that one of them must be used in transparent mode to be able to co-exist?
