Traceroute not working on ACE
fariha zain
My setup is :
Source--- Router 1 ( ip 1.1.1.1) --ACE---router---cloud---customer---router--destination( ip 99.99.99.99).
Traceroute from client to destination shows the following:
traceroute 99.99.99.99
traceroute to 99.99.99.99 (99.99.99.99), 30 hops max, 40 byte packets
1  1.1.1.1 (1.1.1.1)  1.10 ms  1.78 ms
2  99.99.99.99 (99.99.99.99)  1.01 ms  1.97 ms  2.511 ms
3  99.99.99.99 (99.99.99.99)  2.01 ms * 99.99.99.99 (99.99.99.99)  2.330 ms
4  99.99.99.99 (99.99.99.99)  1.11 ms  2.21 ms
5  99.99.99.99 (99.99.99.99)  2.41 ms  2.58 ms
6  99.99.99.99 (99.99.99.99)  3.21 ms  3.150 ms
7  99.99.99.99 (99.99.99.99)  4.89 ms  4.57 ms
8  99.99.99.99 (99.99.99.99)  4.27 ms  4.89 ms
So on this, the destination is 99.99.99.99.The first hop is the default gateway, which is 1.1.1.1.
After that, the next step is the Cisco ACE.After that there are several hops to the destination.
Looks like for some reason the Cisco ACE is not recording his ip.( For any destination traceroute result is the saame.
ICMP is allowed in the access list
and also ther is ICMP inspect in my config.
access-list ICMP line 10 extended permit icmp any any
class-map type management match-any abc
  201 match protocol ssh source-address X.X.0.0 x.x.0.0
class-map match-all ICMP_allow
  2 match access-list ICMP
policy-map multi-match ICMP2
  class ICMP_allow
    inspect icmp error
int vlan 111
service-policy input ICMP2
no shut
Version running on ACE is  Version A2(3.3)
any help would be appriciated.
Fariha
ohynderi
Fariha,
Applying the icmp error inspect should do the trick. Just make sure to apply the policy on the proper interface (ingress or globaly) and that icmp traffic doesn't hit a connection created before applying the inspect (so better to "clear conn flow icmp...).
Olivier
