transaction-logs problem
Muhammed AKYUZ
Level 4
Level 4
Automated transaction-logs export is not working. When i apply the command "transaction-log force export flow " waas exports the logs otherwise it does not export automatically.
config is like that:
transaction-logs flow enable
transaction-logs flow archive interval 120
transaction-logs flow export enable
transaction-logs flow export interval 120
transaction-logs flow export ftp-server 10.1.3.8 ftp **** /
transaction-logs flow export ftp-server 10.12.108.95 a **** /Go
5 Replies 5
Amir Asfandyarov
Did you try to decrease the export interval while leaving the archive interval (and other rows) intact.
So you can try something like
transaction-logs flow export interval 5
and see if it is working.
I have solved the problem but i have another problem..
system does not delete the log files on the waas after ftp export...
Is there any log file capacity limitation or something like that? system automaticaly deletes the older logs?
Archived logs are automatically deleted when free disk space is low.
So it is important to select an export interval that exports files frequently enough so that files are not
automatically removed prior to export.
Regards, Amir
how do you know that? Is there any guide that says like that?
No, this proccess is not documented in the manual, it's part of the internal proccess connected with maintaining the filesystem of the device "healthy".
Regards, Amir
