Troubleshooting connection failure from client.
Chris Thuys
      I have a ACE4710 setup to load balance a couple of web servers. The real servers all show as inservice as do the propbes and serverfarms/virtual servers. If I ping the Virtuual server ip address I get a reply but it I try to access VIP via telnet or web browser. I get a connection could not be open error on the client.
The question is how do i determine where the error is comming from so far I can not tell if the client is getting through the acl or not.
I have used the trouble shooting guide and nothing has helped to determine the cause so far.
show service-policy int479 detail does not show an increase in the hit count when I try to connect.
show stats conn does not show an increase in failed or timed out connections when i try to connect
my config is as below
logging enable
logging fastpath
logging console 4
logging timestamp
logging trap 4
logging history 4
logging buffered 7
logging persistent 4
logging monitor 7
logging device-id context-name
logging host 10.19.56.100 udp/514 format emblem
logging host 10.19.56.101 udp/514 format emblem
access-list ACL_Permit_all line 21 extended permit ip any host 10.19.204.22
access-list ACL_Permit_all line 31 extended permit ip any host 10.19.204.30
access-list ACL_Permit_all line 41 extended permit ip any host 10.19.204.21
access-list ACL_Permit_all line 51 extended permit ip any host 10.19.204.23
access-list ACL_Permit_all line 61 extended permit ip any any
access-list ESP-04-test-vip line 1 extended permit ip host 172.30.0.10 host 10.19.204.30
probe tcp TCP_Probe
  interval 5
  passdetect interval 20
  open 10
rserver host sdc-esp4sgt01
  ip address 10.19.204.25
  inservice
rserver host sdc-esp4sgt02
  ip address 10.19.204.26
  inservice
serverfarm host esp-int-04-4848
  failaction purge
  probe TCP_Probe
  rserver sdc-esp4sgt01 4848
    inservice
  rserver sdc-esp4sgt02 4848
    inservice
serverfarm host esp-int-04-8080
  failaction purge
  probe TCP_Probe
  rserver sdc-esp4sgt01 8080
    inservice
  rserver sdc-esp4sgt02 8080
    inservice
sticky ip-netmask 255.255.255.255 address source esp-int-04-4848-sticky
  serverfarm esp-int-04-4848
  replicate sticky
class-map type management match-any REMOTE_ACCESS
  description Remote access traffic match
  2 match protocol ssh any
  3 match protocol icmp any
  5 match protocol https any
class-map match-all esp-int-04-4848
  2 match virtual-address 10.19.204.30 tcp eq 4848
class-map match-all esp-int-04-8080
  2 match virtual-address 10.19.204.30 tcp eq 8080
policy-map type management first-match mgmt-pm
  class REMOTE_ACCESS
    permit
  class class-default
    permit
policy-map type loadbalance first-match esp-int-04-4848-l7slb
  class class-default
    sticky-serverfarm esp-int-04-4848-sticky
policy-map type loadbalance first-match esp-int-04-8080-l7slb
  class class-default
    serverfarm esp-int-04-8080
policy-map multi-match int479
  class esp-int-04-4848
    loadbalance vip inservice
    loadbalance policy esp-int-04-4848-l7slb
    loadbalance vip icmp-reply active
    nat dynamic 1 vlan 479
  class esp-int-04-8080
    loadbalance policy esp-int-04-8080-l7slb
interface vlan 479
  description "Webmethods Internal Test VLAN"
  ip address 10.19.204.20 255.255.255.0
  access-group input ACL_Permit_all
  access-group output ACL_Permit_all
  nat-pool 1 10.19.204.241 10.19.204.249 netmask 255.255.255.0 pat
  service-policy input mgmt-pm
  service-policy input int479
  no shutdown
interface vlan 481
  ip address 10.19.56.43 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.19.204.1
Kanwaljeet Singh
Hi Chris,
When you try to access VIP, please do show conn and see if you get IN/OUT connection. No counters increasing on service policy may indicate that traffic is not hitting the ACE and i see that you have permit all ACL applied to the interface.
If  ACL is denying the traffic you can easily see that in the logs. You can use show logging for the same. Also, please see show access-list detail.
If you are getting reply for the ping it means that servers are active and operational. Are you able to get the page when you access the servers directly?
Can you take a quick capture on client machine itself and see what do you get? Is TCP three way handshake completing or not etc.
Also, you can take capture on ACE itself using "capture" command and you can see what exactly is going on.
Configuration looks fine.
Kanwal
Hi Kanwal,
                  After sleeping on the issue overnight I realised that as a ping of the VIP was responding this does not neccesarily mean that the VIP is responding to the ping. Especially when the show access-list did not show any increase in the hit count. The light then went on and I discovered I had a nother server on the network which someone had configured with the same ip. It was this server that was responding to the ping. I changed the VIP being used and everything now works.
I would still like to know how to do a packet capture though. I used the command
sdc-lbaint01/VC_WM_TEST# capture wm-test interface vlan 479 access-list ACL_Permit_all bufsize 5000
but what I get does not look like a packet capture I get from snoop/tcpdump/wireshark.
sdc-lbaint01/VC_WM_TEST# show capture wm-test
0001: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0002: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0003: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0004: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0005: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0006: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0007: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0008: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0009: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0010: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
0011: msg_type: ACE_HIT   ace_id: 1739                                     action_flag: 0x13
Hi Chris,
When you ping the VIP on ACE the traffic is not sent at the backend to the servers in serverfarm and as a result you will not see any counter increasing for the service-policy.
But if you have configured "loadbalance icmp-reply active" you will only get the ping response when servers in serverfarm are "operational" otherwise you will not get the response. So in a way if you are getting the ping response it does indicate that servers are up and running. You can also configure the command like "loadbalance icmp-reply".
Regarding the pcaps, please see the link below;
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Troubleshooting_Guide_--_Overview_of_ACE_Troubleshooting
Please visit section: capturing packets in real time
After configuring capture name and acl you need to start the capture, stop the capture and save the capture in disk. Get the capture out of the disk using ftp/tftp and open it in wireshark. Should look like a normal capture.
Let me know if you have any questions.
Kanwal
