True IP Client ACE Module
RICARDO SANCHEZ
Hi It is possible to configure True IP client or something like that in an ACE module? Thanks for your help Regards
Kanwaljeet Singh
Hi Ricardo,
If by "True IP client" you mean that server needs to see the actually client IP even though ACE is natting the source then yes ACE does that.
policy-map type loadbalance first-match L4_HTTP
  class class-default
    serverfarm sf1
    insert-http x-forwarded-for header-value "%is"
%is represents source IP. More details and example can be found at the below link:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/services_modules/ace/vA5_1_0/configuration/slb/guide/slbgd/classlb.html
Kanwal
