Uhhuh. NMI received for unknown reason 2d on CPU 0 error is getting on Cisco ACE console.
ranjith.kanisan
Hi Team,
We are getting following error on cisco Ace console.
PUNE-NDML-ACE-Sec login:
Login timed ou
PUNE-NDML-ACE-Sec login: Uhhuh. NMI received for unknown reason 2d on CPU 0.
Dazed and confused, but trying to continue
Do you have a strange power saving mode enabled?
OCTEON: PCI Error detected, intr: 0x3800
Device is continously rebooting. Kindly suggest this error is related to hardware fault.
thanks in advance
Ranjith
ajayku2
Appears to me like a hardware issue. Please raise a TAC case.
ajayku2
