unable to connect Virtual Blade with VNC
fernandezj
I have WAVE-294 (4.4.7) with licence for virtual blade .
on this wave 1 virtual blade is configured with following parameter:
virtual-blade 1
description w2008
device cpu qemu64
device nic rtl8139
device disk IDE
device keyboard fr
memory 2048
disk 51
interface 1 bridge-group 1 mac-address 00:21:D8:AB:62:EB
cpu-list 1
boot cd-image disk /local1/vbs/winserver.ISO
boot from disk
autostart
exit
the virtual blade is running:
WAAS-FR-COG-CATS-WAVE294-1#sh virtual-blade 1
virtual-blade 1
config:
description w2008
device cpu qemu64
device nic rtl8139
device disk IDE
device keyboard fr
memory 2048
disk 51
cpu-list 1
no boot fd-image
boot from disk
autostart
state:
running
serial console session inactive
vnc server active
no vnc client connected
current cd /local1/vbs/winserver.ISO
current floppy [not inserted]
But with ultraVNC i try to connect vitual blade with destination x.x.x.x:1 (@ip addresse of mgt wave in BVI
you have idea???
best regards
If you have not already installed the OS your boot from statement should be boot from cd-rom not boot from disk.
pdi-594-rtp(config)#virtual-blade 1
pdi-594-rtp(config-vb)#boot from cd-rom
pdi-594-rtp#virtual-blade 1 stop 0
pdi-594-rtp#virtual-blade 1 start
Try changing that parameter and restarting the VB.  Then launch VNC to your BVI address:0
HI
on wave294 no DVD-ROM is present...therfore only boot from disk is possible...
Best regards
fernandezj
I try to connect with tinyvnc and with this client the message is no bootable disk......
Strange the disk is OK on physical machine.
I try with différent ISO:
2003 32b
2003 64b
2003 SP1
2008 R2 32 and 64
2008 32 and 64..
same result....=>
If you have a idea....
best regards
Sent from Cisco Technical Support Android App
fernandezj
Hi Michael,
after some times, i could retest the virtual blade on teh wave, and the goog configuration is :
virtual-blade 1
description w2008
device cpu qemu64
device nic rtl8139
device disk IDE
device keyboard fr
memory 2048
disk 51
interface 1 bridge-group 1 mac-address 00:21:D8:AC:10:38
cpu-list 1
boot cd-image disk /local1/vbs/windows2008R264.iso
boot from cd-rom
no autostart
