uneven box-to-box
f.franceschini
Hi All,
has anyone configured box to box redundacy using different CSS models ?(in my case CSS 11154 and 11501). Any precaution in the redundancy script?
Thanks in advance
Fausto
stevehall
Fausto,
You may want to configure "ip redundancy master" on the 11154 to make it master if it is up.
Also, when running the script, you should be fine as long as you don't use the "-a" switch on it. The "-a" should only be used on 2 identical boxes.
hope that helps
-Steve
