unicast flooding when using CSM
zhichao
The customer got one pair of CSM installed on two switches.
Some servers connected to primary switch (primary CSM), and the rest of servers are connected to the 2nd switch/CSM.
On the 2nd switch, sniffer shows a lot of unicast traffics are flooding to all the ports under the same VLAN (and all the trunking ports).
Is this expected behavior?
Gilles Dufour
are you in bridge mode ?
Do you have HSRP configured ?
There is a well-known bug regarding flooding
CSCei94412: HSRP packets not bridged by CSM causing flooding
This was fixed in 4.2.3
If that does not apply to you, we will need more information - like config, type of packets being flooded [anything in common to those packets ?]
Gilles.
Thanks for rating this answer.
thanks
However we are not using bridge mode.
If this is not expected behavior, I think i have to go onsite to find out more info and do some troubleshooting....
Found the problem.
When the two CSM doing replication, they sent out a lot of unicast traffics flooding the replicacation VLAN.
This does not affect user VLANs.
