Update SSL Certificates to 2048 bit key Certificates for an application
Hi All,
I'm working on task to update the SSL certificate for an application.
Can anybody help me to know on the steps to upgrade the SSL, stuffs need to be checked before and after the installation and how to verify the new certificates.
Thiyagu
sivaksiv
Hi Thiyagu,
Here is the document.
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/ssl/guide/certkeys.html#wp999209
you can verify it on the client browser if the ACE is sending the new certificates.
Siva
